Hello…
I am new to LUUP Coding and need some help.
I am learning how to execute LUUP within scenes.
I have successfully been able to turn things on and off and dim lights etc.
My home has 4 VeraPlus controllers all connected together via UPnP and working fine. Standard Vera scenes are able to turn things on and off etc even if the device is on a different VeraPlus controller than the scene is running on.
My problem is when I write LUUP code in a scene and try to control a device that is on a different VeraPlus controller the code is unsuccessful. The device will not turn on/off/dim etc.
Can you tell me how to address a device in a LUUP scene that is on a different VeraPlus box than the scene is running on… Again all the VeraPlus boxes speak to each other successfully when creating a standard scene in Vera that contains no user developed LUUP code.
Thank You
