I get alerts from door sensors. I have them set inside gates to my home and refrigerators. However when they go off in get 3-4 of the same message. I’m looking how to solve this.
Thanks in advance
Thanks in advance
I use the plug in veraAlerts To solve this problem.
This doesn’t solve the problem. You may have multiple events set-up in different locations like directly on the devices or scenes. If you can’t figure this out please submit a ticket to our support team at support@getvera.com
Thank you, but I no longer use an android so that won’t work in this case
On some devices that would be true. However I just added a new door/window sensor on a fridge and it sends three alerts. I get the same when leaving as well and the geofence sends multiple alerts. When leaving it also sends Gate (door sensor) alerts that never happened.
I use it to generate controlled alerts for my iphone. I have a motion detector that generates two alerts every trip, i set vera to do not notify then receive my one Controlled alert from the plugin.
Best
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
