The last time I had multiple restarts causing performance issues, the forum solved it in a matter of hours. ([url=http://forum.micasaverde.com/index.php/topic,30878.msg226967.html#msg226967]http://forum.micasaverde.com/index.php/topic,30878.msg226967.html#msg226967[/url]) This is what keeps me on VERA.
I need some help again. Getting restarts, here is the log before the latest:
04 06/26/15 11:05:04.230 __LEAK__ this:1630208 start:5488640 to 0x140b000 <0x2b57b680>
01 06/26/15 11:05:09.100 Generic_IP_Camera_Manager::DebugRingBuffers size mismatch 2382449!=0 <0x2b37b680>
06 06/26/15 11:05:13.120 Device_Variable::m_szValue_set device: 185 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: KWH was: 7.0060 now: 7.0060 #hooks: 0 upnp: 0 skip: 0 v:0x986058/NONE duplicate:1 <0x2b57b680>
06 06/26/15 11:05:13.120 Device_Variable::m_szValue_set device: 185 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: KWHReading was: 1435331053 now: 1435331113 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b57b680>
01 06/26/15 11:05:15.100 RingBuffer::SafeToDelete 194 0xcdb408 0 1 0 <0x2b37b680>
01 06/26/15 11:05:15.101 Generic_IP_Camera_Manager::AlarmCallback ALARM_DELETE_RING_BUFFER 194 0xcdb408 <0x2b37b680>
01 06/26/15 11:05:25.105 RingBuffer::SafeToDelete 194 0xcdb408 0 1 0 __LEAK__ this:57344 start:5545984 to 0x1419000 <0x2b37b680>
01 06/26/15 11:05:25.106 Generic_IP_Camera_Manager::AlarmCallback ALARM_DELETE_RING_BUFFER 194 0xcdb408 <0x2b37b680>
02 06/26/15 11:05:34.101 ZWJob_GetNodeDetails::ZWJob_GetNodeDetails skipping return_route for 9 2/1/-1 job job#93 :getnodedetails_ri_poll 9 dev:66 (0x1075140) P:50 S:0 <0x2b57b680>
06 06/26/15 11:05:34.149 Device_Variable::m_szValue_set device: 66 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: LastRouteUpdate was: 1435287923 now: 1435331134 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b77b680>
06 06/26/15 11:05:34.151 Device_Variable::m_szValue_set device: 66 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: Neighbors was: 1,2,3,4,6,7,8,11,13,14,17,18,19,20,21,22, now: 1,2,3,4,6,7,8,11,13,14,17,18,19,20,21,22, #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b77b680>
04 06/26/15 11:05:34.152 <0x2b77b680>
02 06/26/15 11:05:34.216 MMSStorage::GetDataToSend WOKE <0x2fac0680>
02 06/26/15 11:05:34.217 MMSStorage::GetDataToSend abort:1 <0x2fac0680>
04 06/26/15 11:05:34.332 <0x2e416680>
04 06/26/15 11:05:34.333 <0x2e416680>
06 06/26/15 11:05:57.104 Device_Variable::m_szValue_set device: 170 service: urn:akbooer-com:serviceId:EventWatcher1 variable: AppMemoryUsed was: 525 now: 534 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d5a6680>
06 06/26/15 11:05:57.105 Device_Variable::m_szValue_set device: 170 service: urn:akbooer-com:serviceId:EventWatcher1 variable: MemAvail was: 80680 now: 77896 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d5a6680>
06 06/26/15 11:05:57.106 Device_Variable::m_szValue_set device: 170 service: urn:akbooer-com:serviceId:EventWatcher1 variable: MemFree was: 28844 now: 25988 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d5a6680>
06 06/26/15 11:05:57.107 Device_Variable::m_szValue_set device: 170 service: urn:akbooer-com:serviceId:EventWatcher1 variable: CpuLoad05 was: 0.39 now: 0.35 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d5a6680>
04 06/26/15 11:06:04.240 <0x2b57b680>
01 06/26/15 11:06:09.100 Generic_IP_Camera_Manager::DebugRingBuffers size mismatch -50!=0 <0x2b37b680>
06 06/26/15 11:06:13.140 Device_Variable::m_szValue_set device: 185 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: KWH was: 7.0060 now: 7.0060 #hooks: 0 upnp: 0 skip: 0 v:0x986058/NONE duplicate:1 <0x2b57b680>
06 06/26/15 11:06:13.141 Device_Variable::m_szValue_set device: 185 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: KWHReading was: 1435331113 now: 1435331173 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b57b680>
03 06/26/15 11:06:14.100 JobHandler_LuaUPnP::Reload: ring buffer count Critical 1 m_bCriticalOnly 0 dirty data 1 <0x2b57b680>
01 06/26/15 11:06:14.648 UserData::WriteUserData saved--before move File Size: 52864 save size 52864 <0x2b57b680>
02 06/26/15 11:06:14.649 UserData::TempLogFileSystemFailure start 0 <0x2b57b680>
02 06/26/15 11:06:14.682 UserData::TempLogFileSystemFailure 5804 res:1
Is it the generic IP camera? Thoughts? Uninstall pending group opinions.
Thanks in advance.
Paul
