From the MSR release notes:
“NOTE TO EZLO HUB USERS: Ezlo appears to have removed the API that allows a Lua script to be sent to the hub to run, as of their firmware version 2.0.1570.4. There is no replacement API that I can find, so the runlua action is no longer available. At all. If this inconveniences you, I’m sure @Oleh in the Ezlo Community would be interested in your feedback.”
Oleg says they haven’t removed any API however.
I created this rule and it doesn’t work the LUA code is not run on the Ezlo Plus hub.
Looking in the MSR log file I see this:
[latest-21337]2021-12-16T12:44:22.870Z <Rule:NOTICE> Rule#rule-kx8ydvth resetting!
[latest-21337]2021-12-16T12:44:22.871Z <Rule:NOTICE> Rule#rule-kx8ydvth stopping rule
[latest-21337]2021-12-16T12:44:22.873Z <Rule:5:Rule.js:743> Rule#rule-kx8ydvth acquiring semaphore
[latest-21337]2021-12-16T12:44:22.874Z <Rule:5:Rule.js:746> Rule#rule-kx8ydvth semaphore acquired; releasing timer
[latest-21337]2021-12-16T12:44:22.875Z <Rule:5:Rule.js:746> Rule#rule-kx8ydvth semaphore acquired; unsubscribing from condition dependencies
[latest-21337]2021-12-16T12:44:22.878Z <Rule:5:Rule.js:748> Rule#rule-kx8ydvth saving states
[latest-21337]2021-12-16T12:44:22.881Z <Rule:5:Rule.js:752> Rule#rule-kx8ydvth stopped
[latest-21337]2021-12-16T12:44:22.881Z <Rule:NOTICE> Rule Rule#rule-kx8ydvth stopped
[latest-21337]2021-12-16T12:44:22.883Z <Rule:NOTICE> Rule#rule-kx8ydvth restarting after reset
[latest-21337]2021-12-16T12:44:22.884Z <Rule:5:Rule.js:716> Rule#rule-kx8ydvth start(), awaiting semaphore
[latest-21337]2021-12-16T12:44:22.887Z <Rule:5:Rule.js:724> Rule#rule-kx8ydvth restored states: trig=(null), rule=(null)
[latest-21337]2021-12-16T12:44:22.888Z <Rule:5:Rule.js:724> Rule#rule-kx8ydvth subscribing to dependencies
[latest-21337]2021-12-16T12:44:22.888Z <Rule:INFO> Rule#rule-kx8ydvth (Globe Lamp Toggle - Lua) started
[latest-21337]2021-12-16T12:44:22.889Z <Rule:5:Rule.js:728> Rule#rule-kx8ydvth start() dependencies resolved, performing initial evaluation
[latest-21337]2021-12-16T12:44:22.889Z <Rule:5:Rule.js:1005> Rule#rule-kx8ydvth (Globe Lamp Toggle - Lua) evaluate() acquiring mutex
[latest-21337]2021-12-16T12:44:22.890Z <Rule:5:Rule.js:1009> Rule#rule-kx8ydvth._evaluate() mutex acquired, evaluating
[latest-21337]2021-12-16T12:44:22.890Z <Rule:5:Rule.js:1013> Rule#rule-kx8ydvth update rate is 0/min limit 60/min
[latest-21337]2021-12-16T12:44:22.891Z <Rule:5:Rule.js:936> Rule#rule-kx8ydvth evaluateExpressions() with 0 expressions
[latest-21337]2021-12-16T12:44:22.893Z <Rule:5:Rule.js:1033> Rule#rule-kx8ydvth._evaluate() trigger state now (null) (was (null))
[latest-21337]2021-12-16T12:44:22.893Z <Rule:5:Rule.js:1035> Rule#rule-kx8ydvth._evaluate() constraints state true
[latest-21337]2021-12-16T12:44:22.895Z <Rule:5:Rule.js:1041> Rule#rule-kx8ydvth trigger conditions NULL
[latest-21337]2021-12-16T12:44:22.895Z <Rule:5:Rule.js:1042> Rule#rule-kx8ydvth rule state changed, was (undefined) now (null)
[latest-21337]2021-12-16T12:44:22.896Z <Rule:INFO> Globe Lamp Toggle - Lua (Rule#rule-kx8ydvth) NULL!
[latest-21337]2021-12-16T12:44:22.896Z <Rule:5:Rule.js:1044> Rule#rule-kx8ydvth rule state now (null), changed true
