Has anyone looked into a MQTT client implementation on Vera ?
There’s a LUA MQTT client project up on GitHub that should provide a good basis … but wanted to ask here first .
K
K
An MQTT gateway/bridge plugin would be an interesting addition. Thought about it but am severely limited on time - would be happy to test if you put an implementation together, though.
I have a thought…
I think analytics, statistics/reporting (e.g. dataMine) should be outside HA/Vera, instead Vera could publish events (power, temperature,… etc) to a MQTT server outside Vera.
Then http://emoncms.org/ could subscribe on the events and store them for further handling.
For that MQTT Lua client could be used in Vera…
PS. Also a bit driven from that dataMine have been announced (temporarily?!) out of maintenance/development, …is it time to use Emoncms and join forces?! DS
MQTT is verry hot, now it is open source.
Http the internet of people and MQTT “the Internet of Things”
Finaly a fast communication standaard for sensors en homeautomation over ethernet
http://www.willowdesign.info/blog/mqtt-on-arduino/
http://my.safaribooksonline.com/book/-/0738437085/mqtt-and-arduino-devices/mqtt_support_in_arduino
http://chrislarson.me/blog/using-mqtt-connect-arduino-internet-things
dutch:
http://webwereld.nl/hardware/55178-ibm-maakt-machine-2-machine-protocol-open-source
Have you guys tested the Lua MQTT client?
I am trying to get it running but have problems as described here: http://forum.micasaverde.com/index.php?topic=17432
Got it working with some hacks, please checked the thread above
