Move to Edge from now dead Vera2 not so smooth
I got a new edge after Vera2 died. Vera 2 was very stable for me. 40 Switches, 1 lock, 1 thermostat, 1 TV, 1 DirecTv box.
I re-set up the whole network from scratch on the Vera Edge. Waited 2-3 weeks for nightly heals to reroute and repair stuff but still having issues.
  1. I have 8 switches that keep getting the red “Please wait! Getting the manufacturer” error on the Dashboard.
  2. A couple of the switches just don’t respond to the scenes they are in even though Edge says there fine.
  3. Do I need to use “Limit neighbors to Z-Wave discovery (requries Vera routing)”?
I had none of these issues with Vera2.
[quote=“lastmacuser, post:1, topic:188173”]I re-set up the whole network from scratch on the Vera Edge. Waited 2-3 weeks for nightly heals to reroute and repair stuff but still having issues.
  1. I have 8 switches that keep getting the red “Please wait! Getting the manufacturer” error on the Dashboard.[/quote]
how did you re-set up everything? did you remove and re-add all nodes? maybe these switches weren’t removed or added properly. I would go to the one nearest to Vera or a working powered node (to eliminate possible out-of-range issues), reset it (in case it’s hanging) by cutting power to it (via the circuit breaker or by disconnecting the wires), then reconnect. Then try doing a “configure node right now”, if this doesn’t work, try removing the node and adding it again.
I doubt this will help. It will probably make it worse.
