Motion sensor from alarm company
If my current alarm/monitoring setup already has a wired motion sensor in place, and I “port” those over to Vera (by basically replacing the panel with a DSC), will the motion sensor be recognized by Vera as a standard motion sensor? Thanks!
Yes
  • Garrett
Thanks, Garrett!
As long as the sensors are compatible with the DSC panel, you should be Ok.
  • Garrett
