Motion sensor Everspring HSP02
Hi, I just paired the sensor to the controller and I can see it in the Dashboard page but it doesn’t triggered at all. I am not families with the configuration mode and I don’t know how to access the motion sensor set up (i am new with the home system automation…). maybe the sensor is bad? Am i missing something? Thank you in advanced.
I believe it has to do with whether you are running from battery or hard wired power. It is my understanding that the device goes to sleep for certain intervals when on battery.
Even after few hours, it didn’t work so I am going to return it and find other alternatives. I also searched in this forum for a good motion sensor but it seems that every sensor has prons and cons so I think I will use a regular motion sensor (120v) since they are more reliable and can be adjusted locally and connect it to a relay and to a door sensor. the same as I did to my smoke detectors. The door sensor works perfect so I am hoping not to get false alarms and not dealing with the programing (which already complicated in Micasaverde). Thx.
