Motion Detector Programming Knowledge Needed
Any Ideas on using Vera to control a motion detector. I only want it to
be active during a certain time period and that doesn’t seem to
be an option in the scene programing and timer portion of vera.
Basically only want vera to recognize a signal from the motion
detector between the hours of x and y.
You need to write a few lines of lua in the luup event for the scene to return false if the current time is outside of the hours of x and y.
Thanks. Unfortunately that is like telling me I need to do a
differential equation. Are there people here that will write
that type of code for hire or is it commonly available.
I assume you’ve found it by now, but I put the code in your other post.
http://forum.micasaverde.com/index.php?topic=3703.msg18157#msg18157
