Upgraded from UI2 to UI4, and odd things happening.
For instance- I want to change the name of a scene to identify it. I do so and then try to save it. After the save is done,
it still shows “new scene” AND the system has added another identical scene right next to it marked “new scene”!
Deleting the newest scene sometimes works, and sometime not. Because when I go to save it, it sometimes shows back up.
Is anyone else having these strange issues with UI4? Is is possible to downgrade to UI2? Everything worked on UI2 just fine…
Thanks.
