Monoprice Z-Wave Plus Shock Detector and Acceleration Sensor
This Z-Wave Plus sensor detects the vibrations, examples of it use include:
  • intruder trying to break into a window/door
  • someone opening a drawer
  • movement of an object
The sensitivity can also be adjusted, so the system can be configured to ignore spurious vibrations, such as those caused by a passing car with a too-loud stereo system.
It supports both, Shock Sensor capability and also a Vibration/Acceleration Sensor capability, for use with Vera.
This device handler supports the following features:
  1. Reading the following sensors
  • Shock/Acceleration
  • Battery
  • Tamper
NOTE:
  • The vibration sensitivity can be adjusted by opening the unit cover and using a screwdriver to adjust the + shaped white round knob. Turning it clockwise increases sensitivity, turning it anti-clockwise reduces sensitivity
Config:
In order for me to get it to work, I had to configure it as a Door/Window Sensor
Pairing it will show up as GenericIO
https://www.amazon.com/Monoprice-Z-Wave-Detector-Acceleration-Sensor/dp/B01I62YMZM
working pretty well so far, some documentation was stolen from Smartthings
