you pass the device here…
function initialize (lul_device)
but yet you’ve hard coded the device into your function here:
local existingIP = luup.variable_get("urn:nodecentral-com:serviceId:ExternalIP1","ExternalIP", 376)
local oldIP = luup.variable_get("urn:nodecentral-com:serviceId:ExternalIP1","OldIP", 376)
try:
local existingIP = luup.variable_get("urn:nodecentral-com:serviceId:ExternalIP1","ExternalIP", lul_device)
why do you log non-events?
if (newIP == existingIP)
then luup.log("External IP has not changed, so nothing to do")
print("External IP has not changed, so nothing to do")
just look for the state change and act/log accordingly.
did you know that luup.variable.get actually returns two values?
local existingIP, lastUpdateTime = luup.variable_get("urn:nodecentral-com:serviceId:ExternalIP1","ExternalIP", 376)
you can use that, and you wouldn’t need the other variable:
luup.variable_set("urn:micasaverde-com:serviceId:HaDevice1", "LastUpdate", os.time(), 376)
because you already have it!
make it easier on yourself during debug:
luup.log("External IP has changed, so update made")
function logToVera(mssg)
luup.log("MyPluginName: "..mssg)
logToVera("External IP has changed, so update made")
and
tail -f LuaUPnP.log | grep MyPluginName:
props to @akbooer for teaching me some of this!
EDIT:
then the only alternative is they don’t match! So:
if (newIP == existingIP) then
else
-- the other thing
and look to beautify your code for proper indentation:
[code]
local status, ip = luup.inet.wget(“http://checkip.dyndns.org”)
local newIP = ip: match “%d+%.%d+%.%d+%.%d+”
local existingIP = luup.variable_get(“urn:nodecentral-com:serviceId:ExternalIP1”,“ExternalIP”, 376)
local oldIP = luup.variable_get(“urn:nodecentral-com:serviceId:ExternalIP1”,“OldIP”, 376)
print(“My new IP is : '”…newIP…“'”)
luup.log(“My new IP is : '”…newIP…“'”)
print(“My existing IP is : '”…existingIP…“'”)
luup.log(“My existing IP is : '”…existingIP…“'”)
print(“My old IP is : '”…oldIP…“'”)
luup.log(“My old IP was : '”…oldIP…“'”)
if (oldIP == nil or ‘’) then
luup.variable_set(“urn:nodecentral-com:serviceId:ExternalIP1”,“OldIP”, “000.000.000.000”, 376)
luup.log(“No previous IP is present so adding a temporary one”)
print (“No previous IP is present so adding a temporary one”)
then luup.log(“External IP has not changed, so nothing to do”)
print(“External IP has not changed, so nothing to do”)
else
luup.log(“External IP has changed”)
print(“External IP has changed”)
luup.variable_set(“urn:nodecentral-com:serviceId:ExternalIP1”,“OldIP”, oldIP, 376)
luup.variable_set(“urn:nodecentral-com:serviceId:ExternalIP1”,“ExternalIP”, newIP, 376)
luup.variable_set(“urn:micasaverde-com:serviceId:HaDevice1”, “LastUpdate”, os.time(), 376)
– print(“Update made : '”…oldIP…“'”)
– luup.log(“Update made : '”…oldIP…“'”)
print(“External IP has changed, so update made”)
luup.log(“External IP has changed, so update made”)
–end
end[/code]
note how to comment a block of code…
comments here
and here
are ignored
