Mongoose - LuaUPnP Terminated with Exit Code: 250
Hello,
My vera works but I have this error message is attributable to the backup of my configuration.
01 06/09/12 19:02:11.238 Mongoose XXX-mg_stop4 0x992d70 2 1 <0x2b3ea000> 2012-06-09 19:02:11 - LuaUPnP Terminated with Exit Code: 250 2012-06-09 19:02:11 - LuaUPnP crash
Do you think this error is serious?
Should action be on my side?
2	06/09/12 18:47:02.264	ZWJob_SendData  UPDATE MANUAL ROUTE 2=(nil) <0x2bb1d680>
02	06/09/12 18:47:02.269	UPDATE MANUAL ROUTE2 2=(nil) <0x2bf1d680>
02	06/09/12 18:47:02.269	ZW_Send_Data node 2 NO ROUTE (nil) <0x2bf1d680>
06	06/09/12 18:47:02.543	Device_Variable::m_szValue_set device: 3 service: urn:micasaverde-com:serviceId:HaDevice1 variable: CommFailure was: 0 now: 1 #hooks: 0 upnp: 0 v:0x9aa9d0/NONE duplicate:0 <0x2bb1d680>
06	06/09/12 18:47:02.543	Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastError was: Node 3 failed now: Node 2 failed #hooks: 0 upnp: 0 v:0x9bd7b0/NONE duplicate:0 <0x2bb1d680>
02	06/09/12 18:47:02.544	ZWJob_SendData::ReceivedFrame job job#24 :Wakeup done 2 (0x995588) N:2 P:102 S:5 to node 2 command 132/8 failed m_cTxStatus 1 retries 0 <0x2bb1d680>
01	06/09/12 18:47:02.545	ZWJob_SendData::JobFailed job#24 :Wakeup done 2 (0x995588) N:2 P:102 S:5 Priority 102 <0x2bb1d680>
04	06/09/12 18:47:02.545	 <0x2bb1d680>
06	06/09/12 18:49:54.903	Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: LastWakeup was: 1339251838 now: 1339253394 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bb1d680>
02	06/09/12 18:49:54.904	ZWaveNode::Wakeup did a poll for 3 5175 seconds interval 10800 existing (nil) heal (nil) <0x2bb1d680>
02	06/09/12 18:49:54.904	ZWJob_SendData  UPDATE MANUAL ROUTE 3=(nil) <0x2bb1d680>
02	06/09/12 18:49:54.908	UPDATE MANUAL ROUTE2 3=(nil) <0x2bf1d680>
02	06/09/12 18:49:54.908	ZW_Send_Data node 3 NO ROUTE (nil) <0x2bf1d680>
06	06/09/12 18:49:55.253	Device_Variable::m_szValue_set device: 4 service: urn:micasaverde-com:serviceId:HaDevice1 variable: CommFailure was: 0 now: 1 #hooks: 0 upnp: 0 v:0x9aa9d0/NONE duplicate:0 <0x2bb1d680>
06	06/09/12 18:49:55.253	Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastError was: Node 2 failed now: Node 3 failed #hooks: 0 upnp: 0 v:0x9bd7b0/NONE duplicate:0 <0x2bb1d680>
02	06/09/12 18:49:55.254	ZWJob_SendData::ReceivedFrame job job#25 :Wakeup done 3 (0x9a0bd8) N:3 P:102 S:5 to node 3 command 132/8 failed m_cTxStatus 1 retries 0 <0x2bb1d680>
01	06/09/12 18:49:55.255	ZWJob_SendData::JobFailed job#25 :Wakeup done 3 (0x9a0bd8) N:3 P:102 S:5 Priority 102 <0x2bb1d680>
04	06/09/12 18:49:55.255	 <0x2bb1d680>
08	06/09/12 19:02:08.668	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: ModifyUserData <0x2d11d680>
08	06/09/12 19:02:08.668	JobHandler_LuaUPnP::HandleActionRequest argument inUserData={
"devices": {
"rooms": {
"scenes": {
"sections": {
"InstalledPlugins": [
"users": {
} <0x2d11d680>
08	06/09/12 19:02:08.668	JobHandler_LuaUPnP::HandleActionRequest argument DataFormat=json <0x2d11d680>
03	06/09/12 19:02:09.100	JobHandler_LuaUPnP::Reload: ModifyUserData Critical 1 m_bCriticalOnly 0 dirty data 0 <0x2bb1d680>
06	06/09/12 19:02:09.162	Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 2 #hooks: 0 upnp: 0 v:0x9b27f0/NONE duplicate:0 <0x2bb1d680>
06	06/09/12 19:02:09.163	Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: OK now: Resetting ZWave Network #hooks: 0 upnp: 0 v:0x9bd6b0/NONE duplicate:0 <0x2bb1d680>
01	06/09/12 19:02:09.234	Mongoose XXX-mg_stop1 0x992d70 1 1 <0x2b3ea000>
01	06/09/12 19:02:11.237	Mongoose XXX-mg_stop2 0x992d70 2 1 <0x2b3ea000>
01	06/09/12 19:02:11.238	Mongoose XXX-mg_stop3 0x992d70 2 1 <0x2b3ea000>
01 2012-6-9 13:37:20 caught signal 6 <0x2c07f680>
01 2012-6-9 13:52:35 caught signal 6 <0x2c0fd680>
01 2012-6-9 13:52:56 caught signal 6 <0x2c795680>
01 2012-6-9 19:2:11 caught signal 6 <0x2c11d680>
---------------exited-------------
If it’s consistently happening on your box, based upon some action, then it would be worthwhile opening a Support Ticket for the issue.
What plugins do you currently have installed on your Vera?
Hello,
My vera is new, I have no plugin installed.
I just configured my two sensors HSM02 with some Lua scripts that work.
Obviously, this problem only occurs when I click on Save or reload.
Can I try a reset of the box? If so, how?
Want full access to my box ? Option Tech Support in my box?
How to Open a Support Ticket ?
Many Thanks
Looking at your logs, it’s occurring when you do the Save/Reload, at the end of that cycle. The Status 250 itself could simply be indicating that you performed the Save/Reload.
It’s this bit that looks disturbing:
Anyhow, I don’t work for MCV, so I won’t be able to see your machine or anything. You’ll need their Tech Support team for that. You can file a ticket directly from your machine by doing:
a) Navigate to Account → Tech Support
b) Select Tech Support → (Enable)
c) Select Open a New Trouble Ticket → (Continue)
That’ll put the ticket into their queue
Thanks guessed,
I open a ticket immediately.
