Momentary switch: pushed once 2min light on ... pushed twice light stay on
Is anyone able to help me in reaching this target? I use a Fibaro 2x1.5kw rele controlled by a momentary switch. Working on rele parameters I reached the first step: one push to the momentary switch and the light stays on for 2 minuts. I’d like now to be able to keep the light on indefinitely with a double push.
Do you think it is possible?
Thaks. A.
Inviato dal mio GT-P5110 utilizzando Tapatalk
Have you seen the Programmable Logic Event Generator(PLEG) plugin?
Here is the example of how to get just what you want.
Thank you zwaver. I’ll try that sokution…
[quote=“Z-Waver”]Have you seen the Programmable Logic Event Generator(PLEG) plugin?
Here is the example of how to get just what you want.[/quote]
Inviato dal mio GT-I9300 utilizzando Tapatalk
