cheers for the replies… I would like to monitor the power consumption though. that’s why I am after a module that can handle higher power with energy monitoring.
@nullx8 thanx ! that sounds like the most suitable solution. helper contacts are usefull indeed. its modular system right ?
@vas5150 get this http://www.domotica-shop.nl/current-cost-envir-energie-monitor-zwarte-uitvoering-p-16406.html
for max 80A energymonitoring… might need multiple connectors for higher currents.
yes they have clips to hold additinal contacts, and the bolt moved by the magenet is visible on top.
have the advantage that you can operate them by hand and they can adapt to another level.
here from a Moeller modell: http://goo.gl/y6Jr6y (german)
here is a ebay example of a set with 1 additional helper module holding 2 on (NO) and 2 off (NC) switch
the contractor itself has 3 ON (NO) Switches for high load
http://www.ebay.de/itm/Siemens-Schutz-Kombination-3RT1026-1A-Hilfskontakt-/181132865411
well the 99 Bucks are abit overdozed … i just googled for a example, they are sure ALOT cheaper some place else.
have the advantage that you can operate them by handDon't do this! On the off chance that the load has a dead short ... it could blow up in your face ... Plus you do not engage the power as solidly as the magnetic relay.
My dad did this (although it was for more than 20-30A) … He was on a roof and was temporarily blinded.
thats right!
high current leads to “switch sparks” … as higher the voltage the more distance, as higher the current the more intense is the fire.
thats why large conductors make noise if they switching, because the contact plates are punched very hard/fast to the contacts in order to avoid this.
breakers are spring loaded, in order to put as much distance as fast as possible if the switch event happens, (no matter how slow you move the switch) …
but the switch-pin in a Magnetic conductor < 50A is directly mounted to the switch plates.
so you have to operate them “FAST” (punch them in hard) if do manually.
not to mention that the spark fire will destroy the contact plates over time.
yup they need a bounce protection as well, just to make sure the contacts don’t burn away. i once saw a collegue of mine having his 20cm screwdriver put on a 500v 35A rail… ended up in a 10cm screwdriver and a fireburst of over 1.5 meters… its not a kids toy !
i tested some 20A relays allready and they do fine when pushing in by hand. indeed its not a wise idea to do if you don’t know what ur doing ![]()
simpler non-industrial ones could blow up in your face indeed and i wasnt planning on using these. the ones im gonna need are the “hardcore” relays with the plastic cover protection on the switch.
i had similar experience myself but with my watch-strap while fiddling in a Switch Rack,
Titanium alloy turned out not only to be very light, its also VERY Current resistent (the cable it touched where gone in just a few sec. ![]()
well i still operate Conductors manually. (usually its the “helpers” you operate anyway … not the ones carry the large loads)
yeah it’s dangerous stuff. i use this undocumented feature of a 2.5? cable sometimes when i need to weld something :![]()
well hard to create a KugelBlitz with that aproach, but you on the right path ![]()
ROFL
could always try n have a conversation with Chukanov or Tesla… they know the kugelblitz stuff hehe
To control my washing machine i have taken a normal bi stable relais.
i control the coill of therelais with normal fibaro double switch.
the first switch from the fibaro i use to control the 220 v coil of the relais.
the second switch of the fibar i use to verify the position of the relais (power/ no power).
if you use a 10kw relais you can control just with a fibaro
in my opinion keep it as simple as possible; on 23hr the washing machine gets power and start to run until compleet
you can do the same, as long as you use a relais between low current and high corrent/power
rgds
huib
