Modules available for high powered devices?
Looking at powering a hot water system and a large aircon. The modules I have only allow 2300 watt. Aircon needs just over that and the hot water booster even more. Anyone know of any modules out there for this scenario?
You can use an LFM-20 (Z-Wave Relay) to drive a relay of any size.
Goto http://www.grainger.com/ And look for relay … I would find a link that takes you to the PDF catalog … because than you can review all of the pages on relays.
You will want a coil that’s the same as your standard power (110V US).
If you are driving 220/240 Volt load I would get a double pole relay.
Your water heater will use the resistive rating. Things with motors will use the inductive rating.
See if you can find the specs on the coils current. Then find one that has a low coil current.
(This is the power that you will be using just to keep the relay engaged).
you could also use a fibaro duo-switch and have this control the relais richard mentions. or a relais-board with 4 outputs on it.
main thing is that you use a z-wave device that is able to open/close a separate high-power relais.
why always the rocket sience … just get a standard Industry Contactor
(i have some here they can switch 90Amps easy) :wink:
and they did not cost me anything since i grabbed them from a Aircondition-repair shop …
they where left in a dead Compressor unit.
the fibaro (or whatever) switches the Contactor, and the Contactor switches whatever you need/want …
i did the same for my tankless water heaters … as they consume large amounts of Current.
you just have the screw them somewhere not something of steel (because the magnetic hammer makes a knocking noise … mounted to somethings of steel or a weak ceiling … and you will hear it in the whole house :wink:
yup thats more or less the thing i meant by the relais… here in netherlands we call it relais hence why :slight_smile:
see here : [url=http://www.thermostatenshop.nl/123-relais-magneetschakelaar-4polig-25a-spoelspanning-230vac-35mm-breed-8712345123451.html]http://www.thermostatenshop.nl/123-relais-magneetschakelaar-4polig-25a-spoelspanning-230vac-35mm-breed-8712345123451.html[/url]
this one wont make this knockin sound ^^ and can handle 600 switches per hour @ 25 amps 220v
dont know the wording is right … for me it’s just a “SchaltSch?tz” … but we are on the same page :wink:
well mine “knock” because 60amps is alot and the one i have is easy 20 years old (old fashion from Siemens) switches this for 3 phases …
… i solved that with a piece of wood scewed to the wall above the ceiling …
its abit overdosed but rock-solid, the house will fall into pieces before this one fails … for sure :wink:
3 minutes talking to get it + 10 minutes to find a old piece of wood (lucky there is construction next door), total cost 0$ :wink:
:smiley:
yup you could screw the thing to it with some rubber rings under it… works good.
Are we still in the dark ages? Great lumps of steel and copper? ::slight_smile: Solid-state relays don’t knock and 25 Amp modules are pretty small so they may go right into the wall-box. Zero-crossing switching and optical-isolation are fairly standard features. They are all over Ebay and reasonably priced if you don’t mind a few days wait whilst they come from China.
like the one i mentioned, it supports all this stuff u say ? or even smaller then that ?
I’d like to see you fit that into a wall-box. ;D The last one I bought was 40mm square by 15mm high and rated at 25 Amps. The three-phase ones are a little bigger to have room for all the terminals.
just give me a hammer and a chisel and you be supprised what i can fit into a wall ^^
but yes thats small, you have an example/webpage for such device ?
No, the one you mentioned is magnetic with moving parts.
Just the same i use (mine is just overdozed in size with the reason of the unbeatable price of 0$ And delivery time of 10 Minutes)
Besides that, (me being completly honest) i prefer the steel and copper :slight_smile:
One reason is 0 Ohm Resistance,
Another is straightforward integration
Also semiconductors do fail in ON-State, where a magnetic one just stops moving …
Well okay they make noise, and they consume more power.
But wth… The waterheater sucks 5900 watts, the 6watts for the conductor dont really matter in this relation, i guess there is more “loss of current” because of the groundless installation (potential differences) and the poor cables used in the house i live in.
Also magnetic conductors like the one JoJo posted have the advantage that they can withstand ALOT more peak current as its just copper and steel,
1mw too much on a semiconductor and its on forever :slight_smile:
Speed is also not really a question since its may change state in HA 2-3 times a day.
There is just no need for 100hz switching speed :slight_smile:
But if you buy it new, not afraid of soldering things then of course semiconductors are an option. Specially for the noise reasons.
I would probably have done it too with solid state, because if the size advantage.
[quote=“Da_JoJo, post:11, topic:177625”]just give me a hammer and a chisel and you be supprised what i can fit into a wall ^^
but yes thats small, you have an example/webpage for such device ?[/quote]
Jojo, you defently speak my language … Hahahaha
http://www.aliexpress.com/wholesale?SearchText=ac+solid+state+relay&catId=141909&initiative_id=AS_20131103174628
One more thing (i forgot) … Solid states get hot!!
The more current, the hotter they get.
ah ok its a semiconductor one… i don’t fancy these as the’re subject to fail. the one i mentioned is the same electromagnetic switch as yours but it just ticks instead of making a loud knock sound.
edit: no i mean a link to the semiconductor one…
Check Ebay for Solid State Relay - there are thousands of them in many sizes and ratings. A lot of them have 3-32V DC inputs so can be wired across the existing relay coil of a Z-Wave switch. You can get a 25 Amp 380 V single-phase module for less than USD 5.00 shipped.
ah ok its a semiconductor one.. i don't fancy these as the're subject to fail.
The MTBF of an SSR is generally a lot higher than that of an electro-magnetic relay. Take a look inside most washing machines, dish-washers, ovens and other domestic appliances. They've been using SSRs for years. It's usually the electro-magnetic motors and pumps or heating elements that fail not the SSR switches.
mm i need more like a z-wave switch with 220v inputs. the fibaro duo-switch is my favourite as it can handle both AC and DC current 24v-220v . best would be 220v as i dont need any transformers or powersupply to run the stuff. i need some stuff for running 3x35Amps and is able to withstand huge powerpeaks when turned on. using balast-loads 3.2 amps each and peaks of 4.1 amps
Rex is right, assuming they are installed in a controlled envioment like a appliance you buy from the store.
The failure rate is indeed alot higher on a device with moving parts (that is just nature)
But we talking 100 million vs. 500.000 state changes … Both wont happen in Home automation.
Besides the heat, there is the issue that semiconductors are VERY sensitive to peaks and (most impotant)
They are NOT Potential-free.
But if size and speed and cost matters (Specially in mass production) the semis are the winners
so the’re not an option for me considering the high peakloads it must be able to handle. :-/
my uncle wants his greenhouse automated.
we’re talking 380v 5 rows of 3x35 Amp loads and a system to open the ceiling windows and temperature control and automated wateringsystem.
edit: forgot the house also needs to be z-waved. its currently all x10 appliances and since i told him about this vera and z-wave he got enthousiast (offcourse) and wants it now and money is not a problem but it needs to be rock-solid as his and 20 employees lifes dependent on it. im not sure if i can handle this huge project by myself ::slight_smile:
Just one answer for that:
Get magentic conductors!
Potential free, and you can trust them.
If they are large, they make noise, but who cares, its a green-house.
Its not like you do live there.
Also on industrial ones you can add “6 amp helper contacts” to switch other things or build relations between elements, this may save you a few fibaros as well
