Hello all,
did someone already try to update userdata using the
login/password/serial//upnp/control/port_49451/upnp/control/hag uri ?
(from an external client, php, c# or what ever).
If I locally post a SOAP envelop (like described in wiki.micasaverde.com/index.php/ModifyUserData)
in IP/port_49451/upnp/control/hag, then it perfectly works :).
If I post the same SOAP envelop in login/password/serial//upnp/control/port_49451/upnp/control/hag,
I got an 200 HTTP return code but without any SOAP response (and the update that I sent didn’t work) ???.
Any leads ?
Thanks!
