I have some strange problem with x10 sensors over mochad.
The linux mochad server itself is running fine, i can see sensors reacting there. However mochad plugin doesn’t change sensor status on the vera3 and scenes of course not working because of that.
I have other x10 switches and dimmers on the same mochad and can switch them off and on through vera3. It is only sensors are not working. So it is definitely not something simple like network connectivity or wrong ip.
