I’m having a small irrigation system. My service provider conducted a wet check of the irrigation system, watched my fixed spray heads to see if there is a misting effect. An he added that misting is affecting my irrigation.What can I do to reduce the misting effect? I think this is mainly due to the pressure resulting from grade change. Will installing pressure reducer or pressure regulating heads solve my problem?
