Hi
I haven’t used my Vera2 for a long time. I plugged it in to use it again for some new devices in a new building.
I did a factory reset
I did upgrade to firmware 1.5.622
I did login with my username to mios
2nd ERROR: It seems that not all menu items are shown? I can’t add any device, there are no “add device” menu. I can’t get started and I can’t add any z-wave device.
If you go to http://cp.mios.com can you login with your credentials and will it take you to your vera2?
It may have timed out from the mios servers due to disuse and needs refreshed?
I have done factory reset and firmware upgrade.
I can logon to my Vera2
The redirect to /wizard doesn’t work I have to manually enter the /cmh adress to access the GUI.
When logged on I can’t actually do that much, you can review my picture in my earlier post
First I thought it was a java issue, but after I have tried several different laptops I don’t believe that anymore.
I really would like to have some suggestions what I should try
It’s starting to look like your firmware upgrade may not have completed successfully.
Your best bet would be to contact MIOS support so they can help you with this.
I did another factory reset and bam it seems to work! I can now see all the menus. Most likely a hiccup after firmware upgrade!? Anyway, case closed, solved with another factory reset.
