Is oppen luup supposed to mirror room settings from the vera cause mine didnt
VeraBridge has a variable called [tt]CloneRooms[/tt]. If you set it to true it will copy the rooms across, otherwise it puts all bridged devices into a room named after the Vera ID number (PK_AccessPoint.)
See: http://forum.micasaverde.com/index.php/topic,34476.msg290119.html#msg290119
dude you are amazing … where can i donate
You’re very kind. Others need the money more than I do.
There is a link to donate to cancer research on the device panel of the openLuup plugin itself…
If you like openLuup, you could DONATE to Cancer Research UK right here
