I do believe that the expectation if this app maybe a little different to what it’s intent is.
The app checks to see if there are updates to the two files listed below on startup or restart and if there are updates, it will download them automatically. This device is hidden as there is no need to interact with it.
Quote:
Updates the network_pnp_sys.xml and zwave_products_sys.xml files with new versions as they are published.
Yes, for the XML files listed not for any other apps. When you first loaded it, it would have compared what the version on your Vera contains and should have already downloaded the latest. Previously they were released as firmware updates.
Support, or improved support, for a specific device can sometimes be added (by MCV) through updating said files. Rather than releasing an entire new build, the utility may be a quicker way to add support. Or fix things that were broken. The HSM100 V3 originally did not work in 1.5.622, due to a bug in one of these files (it was working in 1.5.459). A simple manual tweak, as originally also documented in the wiki by @Ap15e, fixed it. It is my understanding that the utility now takes care of automatic updates and the HSM100 V3 will work with 1.5.622.
I installed this and now my Schlage BE469 won’t work. I tried removing it and pairing it again, but no luck. I did a restore from a backup and that didn’t fix it either.
I have done it and some devices are being changed by device type causing not to funciton anymore. So for example a specific motion sensor was suddenly not a motion sensor anmore but a “trip” sensor etc. (giving the blue line in polling error). Deinstalling the app didnt resolve the issue. I hade to deinstal the device repair it and ask MCV to loging to my unit to recover.
[quote=“SanderL, post:13, topic:176441”]I would suggest not to use this utility.
No I do not ever touch that link again.[/quote]
Try to change the firmware but keep the old settings. It helped me.
I installed 1.0 of the utility and it bricked an HSM 100 motion sensor. Installed a brand new HSM 100 and it did not install the parent device, but did installed the motion, temp and light devices. Those devices seem to be working ok for last two days. Installed 1.1 and waiting to see what is next. Any ideas on why the parent device did not install?
For HSM100 look for EZMOTION 3in1 sensor posts in this forum, specifically as it sounds like you have a V3, which will look different in Vera to the V1 & V2s. There were issues with these and the earlier firmware, but there were supposed to be addressed in 1.5.622 (the mios update may bring additional stability) - check those posts out as it’s often how you set them up that is important .
For HSM100 look for EZMOTION 3in1 sensor posts in this forum, specifically as it sounds like you have a V3, which will look different in Vera to the V1 & V2s. There were issues with these and the earlier firmware, but there were supposed to be addressed in 1.5.622 (the mios update may bring additional stability) - check those posts out as it’s often how you set them up that is important .[/quote]
If the question is whether or not the Mios Update Utility V1.1 is working. I vote NOT!!
I have spent the last 24 hours trying to get two new V3 HSM100 paired.
I have 8 V1/V2 and they were a pain to pair and I have paired 2 V3 under utility 1.0 but nothing like this. Any thoughts. and yes I have followed the guidance (8 iterations) at:
No luck. This is reminiscent of UI3… Thanks in advance for any help.
Don
UPDATE: After 76 iterations (over 3 days) of pairing and unpairing these two V3 sensors I finally was able to get them working. I believe that I didn’t do anything different on the 76th attempt versus the 1st attempt. Anyone have any thoughts? Think I’m brain dead by now.
There is a forum member called DrZWave who works closely with EZmotion so he maybe able to assist you further via that thread. I only have V1 & 2s myself so cannot contribute to their use with Vera myself.
