What are the pros and cons of each method?
I am guessing that if you use MIOS routing then scene controllers won’t work unless a Vera is on to handle the routing.
Am I right?
I have a Leviton wall switch and three slaves. They all work, but occasionally the slaves will have an annoying 1 or 2-second delay before they trigger the wall switch.
Would ZWAVE-routing fix this?
