MiOS iOS App v1.9
Fixes & Improvements
- The camera speaker volume slider now displays the set value correctly and limits the range to 5-15.
- Fixed an issue where recordings were not properly listed in the MiOS app.
- Fixed issue preventing Property managers from logging out due to an infinite spinner display.
- Fixed inconsistencies in the MiOS app, ensuring the most recent recordings are now displayed correctly.
- EzloPi devices now appear correctly without needing to reopen the app after logging in.
- Fixed an issue where daily restrictions could not be added to PIN codes when the mobile device was set to a 12-hour format.
- Invalid MeshBot creation with Eltako ESB62NP-IP shading actuator has been fixed.
- Fixed a crash in Mios when attempting to add a generic EzloPi device.
- The “Welcome to Ezlo” screen now appears as expected after logging in with an EzloPi device.
- EzloPi devices are now correctly represented, resolving the issue where they were misidentified as Ezlo Atom controllers.
- Fixed several issues with the Swidget plugin:
– corrected device icon for Volatile Organic Compound sensor
– configured the Volatile Organic Compound sensor to support the display of decimals
– corrected display issue with the value reported by the Pressure sensor
Thank you for your continued support, and please let us know if you encounter any issues or have feedback!
Release notes link:
https://updates.ezlo.com/#note1531
