Hello,
We are excited to announce the release of version 1.8 of the MiOS app for iOS! This update includes numerous fixes and improvements aimed at enhancing your experience. Below is a detailed breakdown of what’s new:
MiOS iOS App v1.8
New
- Implemented the UI for Ezlo Aware devices in devices list.
- Added design for the new Ezlo Aware tiles on the dashboard, as well as support for all child devices.
Fixes & Improvements
- Fixed: Partner logo and branding colors now load properly on first login.
- Fixed an issue where live streaming through relay was not working on VC702.
- Fixed an issue where login was stuck causing the app to hang.
- Fixed a condition causing app to crash when opened.
- Fixed app crashing when pairing Ezlo Pi device with custom type.
- Fixed crash issue when configuring EzloPi without Bluetooth connection.
- App now correctly displays “Adopt unsuccessful” when configuring EzloPi device.
- Fixed issue where adopting Ezlo Pi device resulted in a spinning wheel and adoption failure.
- Fixed an issue where live stream did not load after playing a recording from the timeline.
- Display measured values for Multi-sensor A8-9 in Device screen for improved user experience.
- Fixed issue where Eltako Dimmer EUD62NPN-IP was incorrectly displaying On/Off button. The
- device has only dimming capability.
- Updated the icon for Eltako ESB62NP-IP Shading actuator in Meshbots when used as activation event or action.
- Corrected display issues for multiple devices supported by the Swidget Plugin: Pressure Sensor, Air Quality Sensor, Volatile Compound Sensor and CO2 level sensors.
Release notes link:
https://updates.ezlo.com/#note1191
