MiOS App Update for Android version v1.114.1.140
MiOS Android Application v.1.114.1.140
New
  • Ezlo AI Integration and Redesign. Our Ezlo AI for our cameras has now a fresh new look! Users can now benefit from our smart, fast and accurate detection of Humans, Animals, Packages, Motion, and Vehicles. The new design offers easy control of detections, image settings, a timeline and history of events, customizable settings for Motion Sensitivity, Accuracy Threshold, and Hot Zones.
  • ONVIF Camera Integration. Users can now onboard ONVIF-compliant cameras as generic IP cameras. By navigating to ā€œAdd Deviceā€ and selecting ā€œGeneric IP Camera,ā€ the app provides a simple workflow to auto-detect the RTSP stream, test the connection, and add the camera to your account.
Improvements
  • Redesigned MyQ Integration Process. We’ve updated the steps for connecting your MyQ garage door opener. The new process is simpler and has clearer instructions to make setup a breeze.
  • Improved ā€˜Show/Hide Offline Devices’ Logic. The ā€˜Hide Offline Devices’ button now works better. The app will remember your choice, so you won’t have to set it every time you open the app.
Fixes
  • A Smoother Login Experience. Enjoy a more stable and seamless experience right from the moment you open the app. The app now loads correctly and remains stable.
  • Reliable Access to Help. You can now navigate the Help section with confidence. Accessing support and information is seamless and works as expected.
  • Stable MeshBot Filtering. You are now able to reliably filter and view your Cloud MeshBots. The app remains stable and responsive, so you can manage your automations without interruption.
  • Full Control for Honeywell Thermostats in Meshbots. You can now use the full range of actions for your Honeywell thermostat when creating MeshBots, giving you complete control over your home’s climate.
  • Enjoy Fan Mode on Your Thermostat. The ā€˜Fan Mode’ option is now available for your thermostat, allowing you to control your fan directly from the app.
  • View Humidity Levels on Honeywell Thermostats. You can now view the current humidity level from your Honeywell T6 Pro thermostat directly in the app, giving you a more complete picture of your home’s environment.
  • Real-Time Motion Sensor Status. The icon for your motion sensor now updates in real-time on the Devices screen, so you can instantly see when motion is detected.
  • PIN Code Restriction Assignment for Door Locks. You can now be confident that any time limits you set for a door lock PIN code are applied accurately to the correct user, ensuring your home’s security works as planned.
  • Track Energy Use with Shelly Switch. The energy usage for your Shelly 2 PM switch is now displayed in the app, allowing you to monitor its consumption at a glance.
  • Clearer Settings for Alfred Locks. To provide a more intuitive experience, the app now only shows settings that are fully supported by your Alfred DB1-C lock, making device management more straightforward.
  • Generic IP Camera Scripting Parameters. We’ve made under-the-hood improvements to the setup scripts for generic IP cameras, resulting in a more reliable and successful setup process.
Thank you for your continued support, and please let us know if you encounter any issues or have feedback!
Release notes link:
I have an issue on the Android app where I get a ā€œnetwork connection errorā€ that then disappear, but can’t find devices. I have uninstalled and reinstalled to no help. I end up using the web app to manage and control via browser.
Hello @lmacvey
Are you using Samsung? Could you please try cleaning the MiOS app cache and data?
Samsung s24 ultra.
After a data clear, when logging into app it gets a spinning ball of death.
After closing and reopening the app it often loads the dashboard.
Subsequent launches report no Internet connection banner which disappears. However the dashboard rarely loads and wants to start from scratch to add devices.
Very repeatable
Seems the issue is in the app authentication.
Update… not sure if anything was done on EZLO side, but the problem I referenced has seemed to be getting better. Less network connection errors and more consistently loading dashboard. When it does get into that state, I still have to perform a cache/data clean. When the APP is really struggling (meaning cache/data clean not working) I still have to go to the web browser, but often go there to maintain Webbots anyway (someday, maybe the mobile app will have identical functionality as the web).
I should add that phone is running on OneUI 8.0 and Android 16.0, with updates last released on Sept 16th and has this current MIOS thread release.
So back to ground zero… network connections issues, clearing app cache and data…frustrating to say the least.
