Hello @wrathwielder,
Yes, of course! You will receive a new message in a couple of minutes so we can continue working on this.
Talk to you soon!
Talk to you soon!
Cant remember. I attached a zip file to the ticket with the log files in it from that day.
Ticket number was SSOA-327
Thanks.
Did anything come of this? I had to reset my Ezlo Plus and reload all the devices and meshbots. My minimote paired properly and shows on the devices list but I can’t get any button press to trigger a meshbot which was the OPs original complaint. Not I am stuck with the same fate.
I am quite sure the button press is being transmitted because the leds flashes when yo press the button and then a moment later the red led flashes quickly which I believe is in response to an ACK from Ezlo. For some reason the button press is not being parsed in Ezlo Plus properly.
I am on firmware 2.0.78.3067.6
The Minimote worked on this exact ezlo 14 months ago. I have a Zooz ZSE37 button controller working properly, so it is a problem very specific to the minimote.
