MimoLite Garage Controller
I’m working on a new MimoLite Garage controller plugin. Any feature requests?
Broseph, I don’t mean to be a wanker, but, you just posted the same thing three times in a row in three different threads, back to back, in the same sub forum. Some people get really bummed out by that kind of thing.
It’s always good to see new plugin development though. Please keep up the good work!
I was hoping that perhaps some people had a “watch” setup on those other forums so I dropped it in there.
I have to agree with the above. We see you!
in case anybody reads this, I would like to be able to alert me that the garage door has been opened for xx minutes. I am fairly new to this so there may already be a way that I have yet to work out/figure out. I am using a Mimolite with a tllt sensor and it works great other than the display of it as a motion sensor with red lines above when it is open and black lines above the motion sensor when it is closed.
That’s a pretty easy one to do with PLEG, I’m sure there’s other ways to do it but I was already using PLEG to do other things.
Install the free plugin called “Garage Door” from the Vera app store. Input the id number for both the mimolite relay (on/off) switch and the tilt sensors. It will combine it into a single door lock with 2 buttons for lock and unlock which will work as open and clsoed.
PLEG will do your special alert that you asked for as someone has stated.
