These plugins may be used to control MiLight/Easybulb/LimitlessLED Wifi-controlled LED lamps via a Wifi Bridge connected to your home network. The plugins emulate a Dimmable Light (with additional features) so may be controlled through Vera’s UI, scenes, PLXX plugins and some remote apps.
These lamps are being sold in most parts of the world but under various names. I have been assured by the manufacturer that Mi-Light, Easybulb and LimitlessLED are identical products.
There are three types of the lamp: MiLight White, MiLight RGB and MiLight RGB+W. The White version is an energy-efficient white lamp with a good dimming range and an adjustable colour temperature. The RGB version can give you some interesting lighting effects in a variety of colours but does not have a good white. The RGB+W version can be used for both coloured lighting and warm white. Some types of lamp are available in different power ratings (Watts). In addition to normal lamp styles, there are down-lighter and LED strip types available.
Each type of lamp has its own remote control but can also be controlled by Android and iOS apps through a WiFi Bridge. There are two models of Wifi Bridge: The earlier version could control four zones of White lamps and a single RGB zone; The latest version (V3) can additionally control four zones of RGB+W lamps. A zone may include multiple lamps that will be controlled together. Each of the plugin devices provides a Dimmable Light control for a single zone. Multiple devices can be created so that each zone may be controlled separately. Multiple devices of the same or different plugin types may be used with the same Wifi Bridge. Multiple Wifi Bridges may be used to cover larger areas or increase the number of zones.
The control protocol used by these lamps is one-way. This means that the plugin can only know the state of the lamps by what commands it has sent previously. If you control the lamps with a hardware remote or Smartphone app, the plugin will not know this. Should this happen, the plugin can be re-synchronized by selecting Min then Max and then resetting color and/or effects modes. The lamps can also be synchronized to the current Vera device settings by clicking the Sync button on the Control tab.
The plugin for the White lamps is available here: MiLightWhite
The plugin for the RGB lamps is available here: MiLightRGB
The plugin for the RGB+W lamps is available here: MiLightRGBW
Instructions for setting-up and operating the plugins are provided through the Help tab on the plugin’s panel under APPS → My apps. You can also find them here: MiLightWhite, MiLightRGB, MiLightRGBW.
Instructions for setting up the Wifi Bridges: Wifi Bridge Setup. This is also included in the plugin Help files.
For more details on the lamps, see: [url=http://forum.micasaverde.com/index.php/topic,14051.0.html]http://forum.micasaverde.com/index.php/topic,14051.0.html[/url]
Edit: 25/01/2014 11:00 - Uploaded revised Wifi Bridge Setup.pdf including new MiLight V4 Bridge.
Edit: 20/02/2014 17:35 - Changed links. Plugins now in App Store. Removed obsolete edit history.
Edit: 04/09/2014 18:38 - V1.1 of all three plugins to support UI7.
Edit: 18/09/2014 19:10 - V1.2 of all three plugins improves support of UI7.
Edit: 13/03/2015 11:25 - V1.3 of all three plugins released. Fixes display for UI7 7.0.5.
