Is there any easy way to migrate from one PLEG device to another? I want to split my PLEG load into two devices, but don’t want to enter everything that needs to be moved manually.
- From the current PLEG instance, select Editor Options > Backup/Export. Export the entire logic to a file on your computer.
- On the new PLEG instance, which should have NOTHING in it, select Editor Options > Restore/Import. Select the file created in step 1 on your computer and import it into the new instance of PLEG.
- While still in the new instance of PLEG, delete any unnecessary triggers, properties, conditions, ect… keeping only those needed in the second instance.
- Return to the first PLEG and remove all (unnecessary) references to the items now located in PLEG #2. *see note below
- Back up BOTH instances of PLEG again. Use a different name for each. You should have 3 backups now, the combined original and two splits.
- Keep in mind that you will need to have a copy of basic items (such asa 30 second timer schedule if used) in each instance of PLEG where it is called. PLEG can NOT call a schedule in once instance from another instance.
Unfortunately, it seems that it will only restore to the device it was backed up from. I didn’t see a way to override that.
Open PLEG A
Create a backup file.
Close PLEG A
Open PLEG B
Restore backup file created with PLEG A.
Tested and working w Vera Secure on 1.7.3233
