As far as I know we currently can’t make meshbots do TTS via amazon echo devices.
Is it possible for a meshbot to return a status to an alexa routine so it can do TTS based on the return code?
I want a ‘good night’ routine that will turn off lights and set the Ring alarm BUT if the garage door is open then it should just say ‘the garage door is open’ and stop.
