Why would this cloud meshbot set the virtual device to true despite the trigger condition clearly not being met?
I’ve reset the device to false but each time the cloud variable is refreshed, it evaluates as true. Am I missing something or is this a code issue?
Hello @ram
We have created and emailed you a support ticket (303299), check your inbox, please.
Hi @ram
We discovered a small bug here and fixed it immediately. We will be releasing it in next version. but we can manually fix in your meshbot if you need it right now .
@JonathanB can you assist in creating support user for @ram
