I have a multi node z-wave network consisting mainly of Fibaro switches and TKBHome appliance modules. I’ve installed a new Fibaro 1 x 3Kw switch which I can include and exclude by putting the Vera Lite in battery mode and physically taking it to the new switch. When I take it back to its normal location it loses connectivity. I’ve tried placing a plug in appliance module in the same room which the Vera can see and control and I’ve healed the network, but the new Fibaro switch can still not be configured.
Is there anything else I need to do to form the Mesh?
Time.
When you carry Vera to the device, it communicates directly with the device. Then, when you move Vera back to its primary location, it can no longer reach the device directly, as it last did. It is necessary to route communications to the device through other devices. The discovery of neighbors takes a little bit of time and the calculation of routes occurs during network heals.
Vera performs network heals at around 1:00am each day. You can wait until tomorrow, when your device will likely start working, or you can initiate a heal or two right now. To manually initiate a network heal operation log into the Vera GUI console and click Setup → Z-Wave Settings → Repair → Go. Depending on the size(number of devices) of your Z-Wave network, a heal operation can take anywhere from a few minutes for a small network to several hours for a large one.
Assuming that you new device is indeed within range of the mesh, your device will start functioning after a heal or two.
I’ve done one heal, are you saying it will take several? The plugin appliance module that I hope is acting as a router is only a metre or so away and that works fine.
The other thing to consider in the future is there are two options when including, the default and full strength.
If you are still experiencing problems after tonights next heal, you could try excluding the device and a full strength include with the Vera in it normal location.
Yes, if you move devices after they are included, it can take several times for Vera to determine the optimal routing through other devices.
Is there any difference between doing a manual heal and waiting for the overnight one to run?
Will a full strength include use routing as it must to too far away for direct contact now?
[quote=“pnm”]Is there any difference between doing a manual heal and waiting for the overnight one to run?
Will a full strength include use routing as it must to too far away for direct contact now?[/quote]
No difference but this can take a long time to update and determine routing. Most people are a little impatient waiting for thing to wake up and configure.
http://wiki.micasaverde.com/index.php/Heal_Network
When including an item, it will attempt to configure and determine routing table. As Z-waver explained early this is not the same route if the Vera is taken to the device and included. It must sort out this later
It’s had several days now as it’s still not working, so I’m going to replace the Fibaro module and see what happens.
Ok, I’ve swapped the Fibaro module for another Fibaro module and I get the same thing. The plug in appliance module is about 3m away, line of sight but the Fibaro module appears to be in a dead spot.
There is NOTHING at all in the 3m between the antenna on the Fibaro and the appliance module? It’s not sitting in the back of a metal electrical box or behind a chrome plated or metal switch plate?
What if you move the appliance module to a different location? Does that change anything?
