I’m using Vera Lite with RFXTrx433 and a Visonic 433MHz wireless relay MCT-100. It works well. Unfortunately Vera configures this relay as a motion sensor. I do in fact have the relay hooked up to a PIR but really just want to see the state of the contact, either closed or open. No arming or bypassing required.
The reason it’s a problem is that I’m using Homewave Push notification and am getting multiple alerts for each single event. I can’t understand why. Maybe I’ve configured the scene incorrectly but I figure that if the trigger was either an open or closed relay contact status it’d be simple.
So is it possible to change the motion sensor to a relay contact?
Crossed posting is not allowed, in consequence your other post has been removed
