Maybe A Stupid question
Running a Vera 3 with 90 reported devices on latest firmware. Memory and CPU utilization seem fine. All is working, but my nightly Heal that starts at 2AM takes till 8AM Is 6 hours reasonable for the heal, or do I have a problem ??
Should have added, only external code I am running is the Brultech power meter addon with a 30 second refresh rate
IIRC the time taken for a heal is not linear, and get a crazy long the more devices you have.
Anyway, turn off the nightly heal!
Just to follow on from @strangley
Unless you make any major changes, e.g. adding or moving a lot of new z-wave devices or you are seeing long delays in e.g a particulate part of your mesh, a heal should not be needed.
I have not run one on mine for months.
Is there a menu setting that I can seem to find to disable the nightly heal process ??
Yes and a search of the forum would help you find that. If you get stuck searching, then we’ll help you find the setting since its not obvious…
Clue… “Mios routing” :slight_smile:
