In beginning of UI5 there was the same way as now in UI7 for master and slave devices (e.g. fibaro and ezmotion). In the latest UI5 a master device and one slave was there for a 2x1.5kw fibaro. Now again as in the early UI5 days in UI7 there are 3 devices. 1 master and 2 childs. Of which the 1st child is useless and is not updated if controlled. Same for ezmotion 3-1. In UI5 there were 3 devices (light, motion and temperature). Now in UI7 there are 4 of which the child morion is useless as it is not updated (tripped) on motion. Only the master trips…
2 things:
Anyone having same experience and have had contact with MCV about this? Solution on the way?
MCV, if you read along… is this going to be resolved?
