I - in my view - being pretty forgiving about the very first Vera2/UI5 upgrade troubles (floating point fix that broke “everything” on V2/UI5) am now completely out of patience and forgiveness. My initial forgiveness was partially because it was something I could fix with a “simple” “reset to factory settings” downgrade and restore of backup.
Then I attempted to upgrade (again) to UI5 once v1.5.322 was released. That has been an unmitigated disaster and my Vera is presently unable to communicate with any z-wave device in my house. This one I can’t reset to factory defaults and restore a backup because you decided to limit the restore upload size (I understand why) without checking, warning about and preventing the downloaded/saved backup file size from growing beyond the max upload size limit hard coded in restore.sh… (Free product requirement advice & there will be more free advice below)
I have ~45(ish) Z-wave devices installed, so a pretty significant investment made in Z-wave and my Vera (not just materials, but also in terms of time). Additionally, I have recommended Vera to a number of people, including people I know have invested on their own. Don’t I feel great about that recommendation…
The debacle that has been UI5 on my Vera2 has seriously shaken my confidence in MCV as an entity and I will from now on, actively recommend against deploying MCV products to my friends.
@MCV, if you cannot afford to hire product testers and deploy a reasonable & comprehensive QA matrix, or you cannot afford to have a support organization with the resources in place to “cover” for the fact that your QA team is either lazy, incompetent or both, the viability of your company is seriously questionable (and it’s frighteningly visible!)
I have waited for 5(!) days with no substantive feedback on my “My Vera2 is now a brick” support case. This leads me to one of two conclusions (neither which helps instill any confidence in your company!); You’re either so swamped with high priority support cases after rolling out UI5 you’re incapable of responding to another high priority support case (that’s terrible from both a product release management and resource allocation perspective) and/or you do not prioritize “Vera down” as being an important support case.
You did respond to my “Powering off a light with an auxiliary GE/Jasco switches does not update the UI or fire an event in UI4” case within 48 hours (wow, color me impressed… Sarcasm, just in case it isn’t clear). That ticket was reported within 10 minutes of my “Vera Down” ticket, so obviously there is a prioritization problem in your support team. Let me elaborate: one case is “this is annoying and you should look to fix it”, the other is a “Service Unavailable” case. You, in your infinite wisdom decided the “this is annoying” case was more important to resolve… Let me guess, your techs are measured by call resolution volume and there are no internal SLA goals or penalties for ignoring higher priority cases - assuming you - like every other support organization out there - do prioritize the response to your incoming cases based on severity of the issue (and if you don’t, see above)
@MCV: 5 days without addressing a “product down” support ticket is completely unacceptable! And just to be clear: I don’t see how I’ll ever again recommend the Vera as a product!
But I can promise you, me being unhappy and sharing it with the world is not going away!
PS: Just a suggestion… By writing this post, I have presented you with an opportunity to “turn me around” (some people would not need this obvious of a hint, but a face-palm seems to be as subtle as it’s possible to be for you to “get it”). Not everybody understands that the true sign of a good organization is not that they have zero issues (quality and otherwise) - research Apple & “antenna gate” or any number of issues around their iPhone launches if you didn’t learn this in business school (they let you down, ask for your money back!) - it’s how they respond when they have those problems that defines how good they are. Obviously, based on having been a MCV customer since the early(ish) days of Vera1 and seen plenty of examples, I’ve also seen you guys continuously fail to “rise to the occasion”, so I’m not expecting this to be any different. But, I am - actually - a “glass half full” kind of guy and as a result, ridiculously forgiving. Until you stretch it too far. Fair warning; You are very close!
