Marantz NR1603 Control
I have installed Denon Remote app and tested it as marantz is owned by Denon I figured what the hell let me give it a shot. Although I can toggle on/off and raise/lower the volume, I cannot switch sources with this app.
Are there any other IP Control solutions I should explore?
TIA!
I have the same receiver and I figured out how to edit the plug-in config files, so that you can properly select the source.
Go into Apps->Develop Apps->Luup Files and download the 2 files - D_DenonReceiver1.json and I_DenonReceiver1.xml files.
Basically, you have to match the input source labels that the receiver is sending to what is in the config files. You can confirm what values that the receiver is sending by manually changing the input source and seeing what is displayed in the Denon plug-in window. That is the value that you have to put in the two files.
You have to edit the D_DenonReceiver1.json to display the correct labels on the input source buttons and you edit the I_DenonReceiver1.xml file to ensure that the correct values are sent.
I attached my config files that worked with my input sources. Hope it helps
I know it’s been very long but thank you for these, they worked for me :smiley:
