I am having difficulties setting the IP address on my VeraLite manually. I logged into the device and chose the advanced settings option. On the micasaverde site I selected “Setup”, then “Network & WiFi”, and then “Manually Configure”, but nothing happens.
There is a bug in the newer firmware that causes this issue. The preferred workaround is to leave Vera set to use DHCP and create a reservation on your router for your desired Vera IP. The other option is to contact support http://getvera.com/support about setting a static IP.
I ran into the same problem. I had to dig into my router settings and assign it an IP.
Thank you very much, I can do that. Just wanted to make sure I wasn’t missing something obvious.
You might try a different browser also and clear cache, etc first. Mine wasn’t showing any options either on my tablet, but when I was logged on from my computer I was able to get all the additional options to show up to manually configure the settings to my liking.
