I have 2 vera devices at different locations
One is at work the other is at home .
They have different user names and passwords.
How can I use home buddy to manage each of them?
[quote=“yr1, post:1, topic:177076”]I have 2 vera devices at different locations
How can I use home buddy to manage each of them?[/quote]
I am using HB on my Blackberry and can easily manage the many veras I oversee. However I am the same user for all of them. So not sure if you need to add the other username to each etc? I would. From my computer I log in with one username and can easily choose between all the units i oversee.
Not sure if it is the same on all versions but I have the newest APK file I sideloaded on my Q10 and for me it is:
settings > serial …and just select the unit. Since you have different usernnames maybe you need to choose “locate Vera” and enter that log in info for the vera you want to log into.
