Hello, I’m having a bit of a tough time understanding the Advanced configuration of my Aeotec Z-Wave Light strip: https://aeotec.com/z-wave-led-light-strip/
The user’s manual can be found here: LED Strip user guide. : Aeotec Help Desk
I understand how to setup Parameters, but where I’m lost is exactly how to set Parameter 37.
I’m assuming there’s HEX > DEC conversion going on somewhere. But I’m very lost on the whole process.
Basically I want to set the Color display cycle to Rainbow Mode = 1 , Transition style to 0, Cycle count to 0 (unlimited), Brightness to 75% = 75, Time base to 10ms = 1, Color change speed constant = 0
For four bytes, you have a total of 32 bits, which is what the documentation is laying out.
Laying your parameters out as bits, that’s:
00 000 001 01001011 00000000 001 00000
__ ___ ___ ________ ________ ___ _____
| | | | | | +-- color change speed level (0=constant, 5 bits)
| | | | | +-- time base (1=10ms, 3 bits)
| | | | +-- cycle count (0, 8 bits)
| | | +-- brightness (75, 8 bits)
| | +-- color display cycle (1=rainbow, 3 bits)
| +-- color change speed (0, 2 bits)
+-- transition style (0, 2 bits)
If we regroup that into 4-bit “nibbles” it makes 0000 0001 0100 1011 0000 0000 0010 0000
A nibble is a single hexadecimal digit, so all we need to do then is convert the 4-bit nibbles into those hex digits. This is 014b0020 hex.
So set the configuration to “4-byte hex”, and enter 014b0020 and you should be good to go with the parameters you gave.
Binary nibbles to hex digits:
0000 = 0 1000 = 8
0001 = 1 1001 = 9
0010 = 2 1010 = a
0011 = 3 1011 = b
0100 = 4 1100 = c
0101 = 5 1101 = d
0110 = 6 1110 = e
0111 = 7 1111 = f
Wow! Thanks a ton for the help. This worked perfectly
I appreciate it
One other question I had, is it possible to send these parameters via a Scene?
Setting these parameters requires a reload in Luup, so it’s not scene-compatible.
Edit: I should add, you can send the command class directly to the device, and that would change the parameter immediately without requiring a Luup reload (Vera could have done this as well, but chose to do otherwise). It’s a bridge too far for me to chase that down without being an owner of this device, though.
You can probably work it out from this guide:
