Create an Event for Motion detector.
Courtesy of Ap15e – Use the following code
http://forum.micasaverde.com/index.php/topic,5127.0.html
So here’s the modified version that lets you put in # of lights that you want to blink - And the lights go back to their original status after the blinking counter reaches its max…(I’ll update this under AP15e’s sample as well)
--Enter the device ID's here in the array with your device id's
local array_lights = {1,2,3}
local original_status={}
local counter = 10
local delay = 3
function set_switch(device,value)
luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue=value },device)
function tree_on()
for i, device in ipairs(array_lights) do
set_switch(device,"1")
luup.call_delay( 'tree_off', delay )
function tree_off()
counter = counter-1
if counter > 0 then
set_switch(device,"0")
luup.call_delay( 'tree_on', delay )
else
--Set to original status
set_switch(device,original_status[i])
--Save Original status
original_status[i] = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1","Status", device)
tree_off()
