Good afternoon,
I bought a Vera Plus a little over a month ago and I’m still trying to figure out how to pair the devices.
I discovered that I had an equipment already at home that installing a plugin Vera could use it.
Device:[url=https://www.aliexpress.com/item/16Million-colors-Wifi-RGB-RGBW-led-controller-smartphone-control-music-and-timer-mode-magic-home-wifi/32815026302.html?spm=2114.search0104.3.1.198a183d7RQZFO&ws_ab_test=searchweb0_0,searchweb201602_4_10152_5711320_10151_10065_10344_10068_10342_10343_10340_10341_10696_10084_5722520_10083_10618_10304_10307_10301_5711220_10059_5722620_5722920_308_5722720_5722820_100031_10103_10624_10623_10622_10621_10620,searchweb201603_1,ppcSwitch_5&algo_expid=04971058-5e90-457c-a804-c413b981f01b-0&algo_pvid=04971058-5e90-457c-a804-c413b981f01b&priceBeautifyAB=0]https://www.aliexpress.com/item/16Million-colors-Wifi-RGB-RGBW-led-controller-smartphone-control-music-and-timer-mode-magic-home-wifi/32815026302.html?spm=2114.search0104.3.1.198a183d7RQZFO&ws_ab_test=searchweb0_0,searchweb201602_4_10152_5711320_10151_10065_10344_10068_10342_10343_10340_10341_10696_10084_5722520_10083_10618_10304_10307_10301_5711220_10059_5722620_5722920_308_5722720_5722820_100031_10103_10624_10623_10622_10621_10620,searchweb201603_1,ppcSwitch_5&algo_expid=04971058-5e90-457c-a804-c413b981f01b-0&algo_pvid=04971058-5e90-457c-a804-c413b981f01b&priceBeautifyAB=0[/url]
I have already installed and configured, however I only have the options ON / OFF and DIMM is normal or some configuration is missing.
Link with two images that shows the configuration of the device:[url=https://drive.google.com/open?id=1YtifgFgWj70o_mLSK1o93CC8PdpVIBzC]https://drive.google.com/open?id=1YtifgFgWj70o_mLSK1o93CC8PdpVIBzC[/url]
Thanks in advance for your help.
Hi pmdsaude!
I’m the author of the plugin you’re using.
What’s the issue you’re having?
The plugin does not do a very good job of keeping sync with the bulbs/strips if they’re changed from the phone app.
If you’re looking for a specific color, the app can tell you the RGB color codes.
The dimming slider takes the color code you give it and changes everything by the percent selected to reasonably scale the color down for you. At 100% brightness, the strip should be the color you set it to.
Have you set the IP for the unit in the Advanced section? The format is: “10.1.1.128:5577” where 10.1.1.128 is the ip of the unit. You may have to get this from your router.
Hi Ceefing,
Thank you very much for your answer.
My issue, I do not know if it’s a issue :), what’s happening is, after I configure the device on Vera only appear, and works, the option ON, OFF and DIM.
(attach device.gif)
I think that the options to change color will appear also on device first page.
(attach advance.gif)
Which means I always have to go the advanced options of the device to modulate the color or the form, right?
Anyway, you did a great job with this plugin. Thank you.
