I read in the VeraAlerts documentation that you can send an alert using LUUP code.
I’ve got a Scene which, when triggered, I want to send an alert. Here is what I have in the LUUP code for that Scene
luup.call_action("urn:richardgreen:device:VeraAlert:1", "SendAlert", {Message = "Testing Alert!", Recipients = "mdgibbons1"}, 23)
return true
However, when I “Run” the scene, it doesn’t seem to send the Alert (although the rest of the scene’s actions work fine). ‘23’ is the Device id for my VeraAlert Device. I wasn’t 100% sure what to put in the ‘urn:…’. My Device Type for the VeraAlerts is “urn:richardgreen:device:VeraAlert:1” but I’ve tried other variations (ex. without the ‘:1’ at the end). In the recipients, I put one of my ‘Users’ from VeraAlerts but I’ve also tried it with one of the ‘Profiles’. Not sure if this matters.
All of my other alerts (from PLEG, Device Notifications, etc…) are working just fine.
Any suggestions on what I’m doing wrong?
You do not need to call it from LUA
You can call it it from the ADVANCED tab of the scene editor.
You do not have a valid serviceId … you used a deviceId.
Thanks for the quick reply! I found the Serviceid (oops!). The reason I want to call it from the LUA editor is that (eventually) I want to pass along the status of a device on my system (my alarm). I know there is probably some other way (Template Library?) to include another device’s status from the ADVANCED tab but I wasn’t 100% sure how to do it.
Anyway, if somebody stumbles here for future reference, my actual (now working) code looks something like this
alarmstatus = luup.variable_get("urn:micasaverde-com:serviceId:AlarmPartition2","DetailedArmMode",10)
luup.call_action("urn:richardgreen:serviceId:VeraAlert1", "SendAlert", {Message = "Alarm Status: "..alarmstatus, Recipients = "Pushover1"}, 23)
return true
Thanks again!
In PLEG you can have INPUT propertys bound to the variables you want in your message:
i.e.
HouseTemp - Current House Temp
Then when some condition triggers an Action … you can have the action call the SendAlertt action for the Vera Alerts device
Then message would be something like:
The House temperature is {(HouseTemp)}
