I want to display a message to the user during luup plugin initialization, and have it remain for an indefinite amount of time, until a later serial event comes in. luup.task looks perfect for this.
But it looks like at the end of the initialization function, the luup engine clears any message that happens to be showing. In the attached example, the message “end of initialize” is never seen.
The trouble with both of those ls that they are too extreme, and emblazon a huge red banner across the device in the dashboard.
The one you get with returning false (“Lua startup failed”) never goes away. You also can’t control this text.
luup.set_failure() also puts a red banner on the device (“Lua failed”). Passing true doesn’t make this go away immediately either.
Considering that the message I want to display to the user is a reassuring “Please wait, I’m working”, I think these options will do more harm than good.
