[quote=“RichardTSchaefer, post:20, topic:185465”]Sounds like confusion between reboot and LUAUPnp restart.
If you want to find the time of the LAST Reboot … see the date of the file:
/etc/cmh/last_reboot
If you want to see how often and why Vera is restarting … see the contents of the file: /var/log.LuaUPnP
A signal 6 is caused when the user or software requests Vera to restart … this is a NORMAL restart.
You of course will need to be able to SSH Login to your Vera using something like putty.[/quote]
Thanks Richard… i’m actually not confused (for once
), and do mean the LUUP restart (as it’s tagged in the system+monitor plugin, not a reboot.
It seems to be restarting vera 2 out of 3 (or so ) days, always around 9am. while I haven’t noticed any system issues, i’m not the one restarting it, so I was curious if (and why) a plugin was possibly doing it, since it’s a new occurrence.
Vera tech support looked at the logs, and said that while the plugin is notifying me of a restart, vera is in fact NOT restarting.
Attached is his mail… maybe i’m misreading it.?
