Hi @lolodomo - when i have the Sonos plugin and UPnP Proxy installed on my Vera3 UI5 version 1.5.622(memory is fine) Luup restarts once or twice a day with an Exit Code 245. This happens even with only 1 Sonos device and the device is not being used.
When I remove the Sonos plugin the luup restarts no longer happen. I am using the latest version 1.4 of the Sonos plugin and version 5 of the UPnP proxy from the mios app store and I have tried it with Read Queue set to both on and off.
Can you please help me figure out what is wrong? Thanks!
Here is my log:
[code]08 07/01/16 20:11:14.134 JobHandler_LuaUPnP::HandleActionRequest argument action=NotifyAVTransportChange <0x2fe15680>
08 07/01/16 20:11:14.134 JobHandler_LuaUPnP::HandleActionRequest argument LastChange=<Tran
08 07/01/16 20:11:14.135 JobHandler_LuaUPnP::HandleActionRequest argument sid=uuid:RINCON_000E58206C5401400_sub0000001521 <0x2fe15680>
08 07/01/16 20:11:14.165 JobHandler_LuaUPnP::HandleActionRequest device: 96 service: urn:micasaverde-com:serviceId:Sonos1 action: ^[[36;1mNotifyRenderingChange^[[0m <0x2fe15680>
08 07/01/16 20:11:14.166 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=96 <0x2fe15680>
08 07/01/16 20:11:14.166 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:Sonos1 <0x2fe15680>
08 07/01/16 20:11:14.166 JobHandler_LuaUPnP::HandleActionRequest argument action=NotifyRenderingChange <0x2fe15680>
08 07/01/16 20:11:14.166 JobHandler_LuaUPnP::HandleActionRequest argument LastChange=<Volume channel=“LF” val=
08 07/01/16 20:11:14.167 JobHandler_LuaUPnP::HandleActionRequest argument sid=uuid:RINCON_000E58206C5401400_sub0000001522 <0x2fe15680>
08 07/01/16 20:11:14.195 JobHandler_LuaUPnP::HandleActionRequest device: 96 service: urn:micasaverde-com:serviceId:Sonos1 action: ^[[36;1mNotifyZoneGroupTopologyChange^[[0m <0x2fe15680>
08 07/01/16 20:11:14.195 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=96 <0x2fe15680>
08 07/01/16 20:11:14.196 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:Sonos1 <0x2fe15680>
08 07/01/16 20:11:14.196 JobHandler_LuaUPnP::HandleActionRequest argument action=NotifyZoneGroupTopologyChange <0x2fe15680>
08 07/01/16 20:11:14.198 JobHandler_LuaUPnP::HandleActionRequest argument ZoneGroupState=<ZoneGroupMember UUID=“RINCON_5CAAF
08 07/01/16 20:11:14.199 JobHandler_LuaUPnP::HandleActionRequest argument sid=uuid:RINCON_000E58206C5401400_sub0000001523 <0x2fe15680>
08 07/01/16 20:11:14.218 JobHandler_LuaUPnP::HandleActionRequest device: 96 service: urn:micasaverde-com:serviceId:Sonos1 action: ^[[36;1mNotifyContentDirectoryChange^[[0m <0x2fe15680>
08 07/01/16 20:11:14.218 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=96 <0x2fe15680>
08 07/01/16 20:11:14.218 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:Sonos1 <0x2fe15680>
08 07/01/16 20:11:14.218 JobHandler_LuaUPnP::HandleActionRequest argument action=NotifyContentDirectoryChange <0x2fe15680>
08 07/01/16 20:11:14.219 JobHandler_LuaUPnP::HandleActionRequest argument sid=uuid:RINCON_000E58206C5401400_sub0000001524 <0x2fe15680>
04 07/01/16 20:11:14.237 <Job ID=“227” Name=”" Device=“96” Created=“2016-07-01 20:11:14” Started=“2016-07-01 20:11:14” Completed=“2016-07-01 20:11:14” Duration=“0.101580000” Runtime=“0.99228000” Status=“Successful” Last
04 07/01/16 20:11:14.240 <Job ID=“228” Name=“” Device=“96” Created=“2016-07-01 20:11:14” Started=“2016-07-01 20:11:14” Completed=“2016-07-01 20:11:14” Duration=“0.72414000” Runtime=“0.1485000” Status=“Successful” LastNo
04 07/01/16 20:11:14.247 <Job ID=“229” Name=“” Device=“96” Created=“2016-07-01 20:11:14” Started=“2016-07-01 20:11:14” Completed=“2016-07-01 20:11:14” Duration=“0.46168000” Runtime=“0.5091000” Status=“Successful” LastNo
04 07/01/16 20:11:14.249 <Job ID=“230” Name=“” Device=“96” Created=“2016-07-01 20:11:14” Started=“2016-07-01 20:11:14” Completed=“2016-07-01 20:11:14” Duration=“0.29157000” Runtime=“0.617000” Status=“Successful” LastNot
^[[7;36m2016-07-01 20:11:25 - LuaUPnP Terminated with Exit Code: 245^[[1;00m
^[[7;36m2016-07-01 20:11:25 - LuaUPnP crash^[[1;00m
01 2016-7-1 20:11:25 caught signal 11 <0x2e991680> [/code]
