I am using reactor in openluup which I installed on my Pi4. Now I also use VeraAlerts on my VeraPlus. VeraAlerts does not work on openluup. To activate VeraAlerts, I have to use scene on my VeraPlus again what I don’t want. Is it possible to activate VeraAlerts via Luup Requests in openluup (reactor) on my Pi4?
In VeraPlus I activate VeraAlerts with the Luup code below.
luup.call_action (“urn: richardgreen: serviceId: VeraAlert1”, “SendAlert”, {Message = “backdoor open”, Recipients = “office”}, 1133). I may also be able to activate it in openluup with a luup request.
something like this should work. http://ip_adress:3480/data_request?id=action&DeviceNum=1133&urn:richardgreen:serviceId:VeraAlert1&action=SendAlert&Message=backdoor%20open&Recipient=office
I would also point out that Reactor now natively has many of the notification options VeraAlerts has. It’s a simpler model than that of VeraAlerts, but that’s not always a bad thing.
See: Notify Action in Reactor docs. This does not describe the recently-added support for Pushover and Telegram.
Yep!
And I’m migrating my alerts to Reactor’s native Pushover notification. Much Thanks!
But I did want to point out the VA option. (It was easy to use in Reactor)
Chris
