ElCid
1
ok i am trying to set a variable via a http request locally
i am sending
http://192.168.3.201:3480/data_request?id=variableset&DeviceNum=133&urn:bochicchio-com:serviceId:VeraAlexa1&Variable=OneTimePassCode&Value=111111
But it is adding a variable in the advanced-params.
I would like it to update the variable in advance-variables
what am i doing wrong?
the serviceId is copied from the variables edit dialog.
akbooer
2
You need the serviceId
parameter. Also you should use /port_3480
http://192.168.3.201/port_3480/data_request?id=variableset&DeviceNum=133&serviceId=urn:bochicchio-com:serviceId:VeraAlexa1&Variable=OneTimePassCode&Value=111111
ElCid
3
Cheers i could not see i failed to add servicId=
ElCid
4
does it matter if the request is POST or GET?
if i send by browser it fine
if i send by http post request nothing happens
edit/
never miund worked it out I was urlencoding the serviceId
all request are local
