Luup pronto codes?!?
So for the past 8 months I’ve been living with sq remote to do things I thought vera would be able to do with the sq blaster plugin. I have tried parsing the files from box.net atleast 10 times and creating a device, or modifying one, playing with the code, and nothing work. I tried again tonight with no luck. So I thought I might as well just teach vera the codes. Nope doesn’t work either, when I am in programming mode a box comes up saying “no IR blaster”.
I give up.
I have the pronto codes from the parsed files, if someone could please give me an example of how to use them, it would be appreciated greatly. (no UI4 experience, so I haven’t done any real code or scripting thanks to the pleg plugin)
Here’s what I got:
urn:micasaverde-com:serviceId:TogglePower1 OnOff Pe8d9 decb 03b6 adf9 ace3 e7dd 464c 4ac2 7952 00e0 0d9f e5d4 16bf 8718 c86e 9822 a870 4b86 0215 ec29 d050 a6f5 81f7 a96d db86 c530 46c6 4612 5a1a 1f9e bb4b 2550 0c12 86fd 4a86 b236 7464 f0a9 681a 9e9f
I’m assuming
is the actual pronto code.
So I think if I make a scene for every “button” I want to use, It’ll end these sleepless nights and maybe help others out there. I know I can’t be the only one that’s given up trying the “easy/easier” ways.
Thanks in advance!!
